WONT RETRACT ALL THE WAY IN
I have a RM6095S-45 that reaches out normally but stops about 2 inches from retracting all the way back in. It will reach and retract normally when calibrating but as soon as calibration is saved and the truck is powered off then on, it repeats the same issue. i have replaced the reach sensor, swapped out Access 7 and Access 4, reloaded software and even replaced accessory pump (recommended by Crown). nothing has worked. Am i missing something? Thanks in advance
  • Posted 14 Jan 2020 08:12
  • By NJ2ATL44
  • joined 14 Jan'20 - 2 messages
PCW III
on that reach sensor, did you check the socket part the sensor stem inserts into for wear?
make sense?
if its worn it may be sending an incorrect signal in normal mode, when your in calibration mode it may be bypassing the limit which allows it to travel fully which in turn is confusing you.
  • Posted 14 Jan 2020 21:42
JLG G12-55A
Toyota 3FD100
Sue Tomic Sue Tomic
