Hyster H80XM LPG
Hi, I am having a issue with the forklift stumbling. Starts and runs fine but at idle it will stumble like it's about to die for about 1 second, then run fine again. This happens about every 5 to 10 seconds. If I give the unit throttle it will rev up, but it still stumbles, about every 5 to 10 seconds at higher RPM's.
Thanks in advance for the help.
  • Posted 22 Nov 2019 11:06
  • By Cainsable
  • joined 22 Nov'19 - 2 messages
some of these units have what they call a dashpot on the throttle.
if it is not adjusted correctly it can allow the throttle to drop too low or have a surge in it like what you are describing.
On the higher rpm's i'm not sure what that might be unless it has a mechanical governor on it, if thats been tampered with it might be out of adjustment causing that surge.
  • Posted 3 Dec 2019 16:53
  • Modified 3 Dec 2019 17:03 by poster
Serial number is K005D02373X. It is run by propane(LPG). Thanks.
  • Posted 30 Nov 2019 04:31
  • By Cainsable
Serial number please it will help to be able to work out what model fuel system is fitted
  • Posted 23 Nov 2019 05:25
  • By lifter01
  • joined 4 Jul'09 - 463 messages
