wiper driver code???
I have a 524238-4 wiper driver code it says for rear wiper but neither the front or rear wiper will work. Does anyone know where these drivers are stored? Cluster??? Or could one one the wiper motors be shorted out causing the other to fail???? i am going to isolate each motor but figured it cant hurt to ask.....Thanks
  • Posted 30 Sep 2019 22:25
  • By POWERSHOP1804
  • joined 16 May'19 - 17 messages
  • New Jersey, United States
My manual says its the rear wiper motor??
There is a relay in the roof headlining, just check that first, I had one that was throwing a windscreen washer motor fault and it was the relay.
Its like a double sided relay you can turn it 180 degrees in the socket from memory.
  • Posted 18 Nov 2025 02:23
  • Modified 18 Nov 2025 02:27 by poster
  • By andrew_k
  • joined 17 Mar'07 - 338 messages
  • England, United Kingdom
I know you posted this quite a long time ago, but I'm having the problem also. The manual actually says to replace the front wiper motor. Which I did. Still has the code front and rear wiper do not work. 524238-4. Love to know what you did to solve this
  • Posted 17 Nov 2025 06:29
  • By adam_n
  • joined 7 Sep'17 - 10 messages
  • Utah, United States
An
Lift Technologies Inc.
Sue Tomic Sue Tomic
