Boss WA151-18135 order picker
I have a boss type order picker type WA151 whose software system running by junghirch.. I have a problem when I try to operate the truck and press the diedmanswitch it show an error 343 and doesn't make any motion neither hydraulic nor movement.
Can any one help me to sole this problem ?.
Thanks in advance.
  • Posted 17 Sep 2019 07:27
  • By abdo_Embaby
  • joined 8 Sep'19 - 6 messages
  • Egypt
The sensor in the hydraulic valve block may be faulty or the shuttle vale could be stuck. If yuo remove it and place close to a metal object you should see the LED illuminate and the truck will operate. Had one where the armature on the hydaulic motor was sheard off so there was no pressure to operate the shuttle valve.
There is diagnostic software available for these trucks.
  • Posted 7 Oct 2019 22:11
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
REPOWERTEK Inc
Michel Denis Michel Denis
