Trans slips going forward
1985 Cat V50D Serial number 3EC1100. It has the peugeot LP engine with auto trans. Fresh trans fluid and spin on filter. Converted to gas. Runs very well. Just purchased this truck and have been fixing it up. When you put it in reverse it drops the RPM's and engages pretty hard. When the electric switch is put into the forward position the RPM's barely drop. It looks like it has a hydraulic inching pedal set up. I checked the pressure from the external hoses. Forward is 60 psi. Reverse is 120 psi. I do not have the two solenoids sticking out the front like others I have researched. The wires go in from the backside of the trans. It has two cover plates on top I'm guessing the solenoids are under there. I do not have a manual or a clue where to go from here.
  • Posted 2 Sep 2019 08:55
  • By DirtyDingo
  • joined 28 Aug'19 - 4 messages
  • Arizona, United States
looking for any info I can get on auto trans, fkow diagagram, piping I/O info, elect info
  • Posted 21 Feb 2020 00:06
  • By butch_s
  • joined 15 Feb'20 - 3 messages
  • Wisconsin, United States
I have a CAT V50D and can't even find the fwd / reverse solenoids on mine !!
  • Posted 20 Feb 2020 08:27
  • By ratter
  • joined 2 Feb'19 - 9 messages
  • United Kingdom
Ever find an answer I have cat V50D no Ser# used on tracked machine
have slow movement but that is all
ever find a cheap manual for this lift truck ??
  • Posted 15 Feb 2020 00:35
  • By butch_s
Komatsu FD25T17
Unicarriers FHGE35T5S
