BT RRE160 replacement LID
Hi guy!
I have a truck BT RRE160 defective LID.
Does LID replacement (load information display) need to be installed? and how to install?
thank you!
  • Posted 30 Jul 2019 00:49
  • By tinhtinh
  • joined 30 Mar'19 - 33 messages
  • Viet Nam
tinh0972857693@gmail.com
hi
I have software BT TruckCom.
Currently I don't have a cable connection, maybe I will buy it from TVH to solve the problem.
Do you have documentation or video tutorials that cover LID?
Help me!
  • Posted 2 Aug 2019 01:23
  • By tinhtinh
  • Viet Nam
You need BT Truck Com software to install a new LID.
New LID come with NO truck firmware installed.
Do you have access to BT Truck Com diagnostic software?
  • Posted 1 Aug 2019 02:12
  • By Forkingabout
  • england, United Kingdom
hi
LID of truck defective Capacitor ( C127).
Can you share install details LID with truck for me.
Version of truck: 260038-015
Version of LID:260868-003
Thank you.
  • Posted 1 Aug 2019 01:34
  • By tinhtinh
  • Viet Nam
A new LID would require the software installing with BT TruckCom software before it would work - they come with NO software installed.
What is wrong with your current LID?
There is a known fault where the solder joint breaks at the connector socket due to the plastic body of the socket vibrating, take the LID apart, where the main black connector socket is turn the PCB over & you will see the 4 pins soldered to the PCB - the solder joints break there.
Reflow the 4 solder joints & then add some glue / silicone sealant to the black plastic part of the connector socket to hold it securely to the PCB.
  • Posted 31 Jul 2019 01:03
  • By Forkingabout
Nagano NUZ090D
Toyota 02-8FD30
Sue Tomic Sue Tomic
Nagano NUZ090D
Toyota 02-8FD30
Sue Tomic Sue Tomic
