Toyota 5FBC25- Very fast/jerky -lift,tilt and side shift
Is there any way to control the hydraulic speed on an older 5 series electric. Customer complains that Hydraulics are very fast and jumpy. Any ideas would be appreciated, Thanks
  • Posted 22 Aug 2008 23:54
  • By Prentice
they could also step off the gas wail useing HYD's
  • Posted 4 Sep 2008 23:00
  • By dantheman
  • joined 4 Sep'08 - 18 messages
  • New Hampshire, United States
Simons is right u just cant dead blow the spool valve they will blow out pickings if they keep fully opening or closing the spools they need to be careful
  • Posted 4 Sep 2008 22:36
  • By dantheman
Are they used to a newer machine?...obviously the pump runs full tilt on older trucks but the valve blocks are always controllable. I've known a single segment to go 'fierce' but never the whole block. You could tell 'em to not pull the levers so **** hard!!
  • Posted 29 Aug 2008 05:45
  • By simon_k
  • joined 31 Oct'04 - 147 messages
  • Devon, United Kingdom
I am assuming no one has had this problem????????
  • Posted 29 Aug 2008 00:14
  • By Prentice
