Code 65
Hi there. I have a Toyota 7BRU18 (s/n7BRU18-34965) that is intermittently showing code 65 on the display as well as "Neutral?". I do not have a manual for this unit and am looking for any help on this issue. Thanks in advance
  • Posted 23 May 2019 06:18
  • By Likwid13
  • joined 17 Jul'15 - 14 messages
  • Alberta, Canada
U can try to readjust deanman limit switch or at least verify it's working...but will probably need to relearn joystick...too much to go through here...recommend calling local Toyota tech...sorry
  • Posted 7 Apr 2025 02:54
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
65=Deadman Pedal Potentiometer and Deadman Switch Do Not
Agree
61=Steer Error
  • Posted 6 Apr 2025 06:31
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
Hi how you fix this code 65 thanks have the same problem and no drive sometimes work if relees brake the code pop up.. sometimes code 61
  • Posted 3 Apr 2025 08:52
  • By armando_g
  • joined 11 May'18 - 48 messages
grgarryciencia@aol.com
Hi how you fix this code 65 thanks have the sane no drive
  • Posted 3 Apr 2025 08:51
  • By armando_g
