Error E250
Machine will sound the horn and display Error code E250 when trying to operate. Does anyone know common diagnostics for this error code or have an electronic copy of the manual?
  • Posted 21 May 2019 02:24
  • By devon_r
  • joined 21 May'19 - 2 messages
  • Louisiana, United States
I wouldn't say its a problem that they need to own up to. Its just another safety check that the machine has. If the charger does not see 24v in the battery bank then it wount try to send power to change them. If the batteries are low and there is a bad cell then the last thing you would want is to try to charge it. Common sense.
  • Posted 22 Nov 2019 06:40
  • By Bryan_Fette
  • joined 22 Nov'19 - 1 message
If its the same as Toyota 8Hbw23 pallet jack then it's the machine not setting the charger. Check wiring between machine and charger and try plugging charger to 110 power to reset. It's the worst pallet jack Raymond/ Toyota ever made. Problem is they won't acknowledge its inherent Problems.
  • Posted 16 Nov 2019 00:11
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
Dreamt I was fixing a machine, then came the paperwork and it turned into a nightmare.
I have the same code, did you able to fix the issue?.
  • Posted 15 Nov 2019 12:07
  • By Tom_Tom
  • joined 15 Nov'19 - 1 message
  • Virginia, United States
HS
Toyota 8FD45
TCM FHD105Z
Zhejiang UN Forklift Co., Ltd
