Lowering goes very slow
Need an little help. Our order picker goes down very slow, I have also tested the manual lowering **** and it does the same thing.
  • Posted 19 Jul 2018 08:39
  • By DTucker
  • joined 11 Jul'14 - 35 messages
It was a bad flow control valve, part number 520-163. The Raymond master technician said in 30 years he has only replaced one of those.
  • Posted 8 Oct 2019 07:59
  • By DTucker
D. Tucker
Check your Proportional Valve
  • Posted 19 Aug 2019 00:53
  • By DBell
  • joined 14 Aug'19 - 3 messages
It is possible there is a blockage in the flow control valve.
  • Posted 2 Aug 2019 22:27
  • By BREWSKI
Manual lowering is limited speed wise.
  • Posted 2 Aug 2019 22:25
  • By BREWSKI
Since the manual lowering does the same thing it seems more like a hydraulic issue than a electrical issue
  • Posted 2 Aug 2019 08:55
  • By joseph_d
  • joined 2 Aug'19 - 2 messages
If it is proportional lift/lower it could also be the potentiometer.
  • Posted 2 Aug 2019 05:58
  • By BREWSKI
Depending on the model you may need to recalibrate the joystick.
  • Posted 2 Aug 2019 05:57
  • By BREWSKI
Hi I was wondering if you figured out the issue to this problem I see no one replied and I'm having the same issue with a Yale order picker
  • Posted 2 Aug 2019 04:51
  • By joseph_d
Briefs United States
TCM FHD105Z
Elwell-Parker ESI500-36
