no lift function
working on an older TM15s good main power fuse,new contact tips,pump will run fine manually depressing the contactor. this lift does not have a lift cut-out like a curtis controller. good battery voltage. control wires on the contactor are 30 and 28. Does anybody know if this machine has a small fuse for that curcuit,and where does this curcuit get its power from.
  • Posted 24 Jun 2018 09:57
  • By deadshort
  • joined 22 Jun'14 - 6 messages
i may have some helpful info, contact my profile
  • Posted 28 Aug 2018 12:53
  • By tom_p
  • Alberta, Canada
Apparently this model on later versions used a coil driver on the contactor so they had problems latching. This was a back up lift and i got kicked off the repair as they did'nt want to spend any more money. I think the controller is the problem.If you manually close the pump contactor does the pump run ?
  • Posted 24 Aug 2018 08:52
  • By deadshort
daniel grue
Did you find the problem? I am having the same issue on a TM15. I have steering, forward, reverse, the pump is running, The lift and tilt levers actuate the right most contactor but nothing happens. I've tried manually closing two contactors that are not related to steering or directional control.
  • Posted 24 Aug 2018 07:24
  • By Andrew520
  • joined 24 Aug'18 - 1 message
  • Arizona, United States
SMV (Konecranes) 12-1200B
SMV (Konecranes) 16-1200C
edition #1257 - 20 November 2025
Columbus, United States
Oxford Ct, United States
HD Hyundai XiteSolutions receives order for 230 forklifts Caracas, Venezuela, Bolivarian Republic Of
