Forward/reverse issue
Hello all!
I just picked up an old propane c500 fork lift.
The engine runs fine but with the accelerator to the floor it just barely creeps along in low range. From what I understand is has the hydratork transmission.
I'm an automotive tech, but this system is kind of foreign to me.
Any thoughts?
Thank you!
  • Posted 17 Apr 2018 13:21
  • By BrokenAxle
  • joined 17 Apr'18 - 2 messages
  • Alberta, Canada
Thanks guys. I'll check those out and report back!
  • Posted 18 Apr 2018 01:29
  • By BrokenAxle
  • Alberta, Canada
There is a dip stick on the drive axle. This is for the transmission. Check the fluid level with the truck idling. It uses Dexron trans fluid.
  • Posted 17 Apr 2018 22:55
  • By BREWSKI
Follow the brake line that goes to the transmission. It leads to a valve that releases the trans pressure. It is activated by what looks like a wheel cylinder. It has springs in there that that break and won't let the valve close.
  • Posted 17 Apr 2018 19:57
edition #1257 - 20 November 2025
Oxford Ct, United States
