No Lower
No lower but everything else working fine (Lift & Drive)
battery fully charged, fuses all test good.
switch signal good to platform terminal block.
also good to distribution panel.
measures 24 volts until lower switch pressed then drops to 2.5 volts.
back to 24 volts when released or coil disconnected.
(tried switching coil, no difference)
  • Posted 6 Feb 2018 06:23
  • By newbie705
  • joined 19 Sep'17 - 10 messages
Thanks techn_nz, I had already confirmed the cables good, had swapped out the fuses and distribution board with no luck.
spent some time to trace wiring and found issue to be a bad chain slack switch on the power side. no error on slack chain though.
all previous checks had been on switch side, no thought given to power side because common to other options working.
Problem now solved.
  • Posted 6 Mar 2018 04:56
  • By newbie705
You need to follow the wire back from the lower solenoid valve and find where the voltage drops from 24 to 2.5, most likely either a mast cable or distribution board issue, swap the fuses first though as that's the easiest fix and i've had corrosion between fuse & fuse holder before that gave the same symptoms.
  • Posted 2 Mar 2018 16:03
  • By techno_nz
  • Canterbury, New Zealand
Crown RD572513TT6860R
Mitsubishi FD200
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
