No Start
I have a Toyota 7FGU25 (s/n73144) that wont start after sitting overnight. If I give it a shot of brake cleaner in the carburetor, it will fire up and run fine. It seems to restart ok throughout the day. It is a dual fuel system, but only ran on LPG. Any thoughts?
  • Posted 15 Sep 2017 00:14
  • By Likwid13
  • joined 17 Jul'15 - 14 messages
  • Alberta, Canada
What symptoms does your truck have? is the regulator icing up?
  • Posted 18 Dec 2020 02:16
  • By Triggs
Did you ever figure out the problem
  • Posted 18 Dec 2020 01:42
  • By Andrew_Cuello
  • joined 18 Dec'20 - 5 messages
  • Hawaii, United States
AC
Did much come out? It has to be drained when the engine is hot.
Sometimes draining won't do it and you have to open it up and clean everything. At that point you might as well put new diaphragms filter and seats in it.
  • Posted 15 Sep 2017 07:05
  • By stam
I did drain the oil from the regulator, and the condition has persisted.
  • Posted 15 Sep 2017 02:21
  • By Likwid13
  • Alberta, Canada
Lpg regulator plugged up with heavy ends (tar) from the lpg.
  • Posted 15 Sep 2017 01:45
  • By stam
Maxlion R2D35
Terberg RT403
Maxlion R2D35
Terberg RT403
