no lift
Hi all,
Looking for some guidance for issue where on full charge battery reads 36.9vdc yet will not lift forks.
Also, the battery indicator lights are not on except last light and it flashes continuously.
I would like to say what model year my truck is but I don't know and can't find it on any spec plates.
Thank you
  • Posted 14 Jun 2017 02:13
  • By burnie
  • joined 14 Jun'17 - 4 messages
Most grateful for your input Brewski
The equalize charge seems to have provided enough juice to knock some of the corrosion off the plates to allow the string to reach 38.5vdc
Forks are up and we're back in business
Kind regards
  • Posted 15 Jun 2017 05:15
  • By burnie
2.12-2.15 per cell after cool down is a charged cell. This will be different for AGM sealed batteries.
  • Posted 15 Jun 2017 02:51
  • By BREWSKI
cool, thank you... that is good to know.
So, I reckon I've got a bad cell in the string.
I'm assuming a good, fully charged cell should be at about 2.2vdc and I'm at 2.05vdc
I'll try an equalize charge and see if I get any improvement.
Thanks for your help
  • Posted 15 Jun 2017 00:05
  • By burnie
By my chart it is a 1998 model.
  • Posted 14 Jun 2017 22:34
  • By BREWSKI
Thanks brewski,
The serial number is 1A197236
  • Posted 14 Jun 2017 07:14
  • By burnie
You are not getting a full charge. You should be around 38.5 volts. 36.9 is not enough to reset the lift interrupt. Post the serial number and we may be able to age the truck for you.
  • Posted 14 Jun 2017 06:27
  • By BREWSKI
Sue Tomic Sue Tomic
