Sticky Emergency Brake
Hey! So our forklift, when you pull the emergency brake handle, the emergency brake foot pedal only comes half of the way up, so it is still partially engaged. Is there an easy fix to this, such as tightening a wire or lubing it up? Thanks so much!
  • Posted 12 Jun 2013 05:00
  • By patrick_a
  • joined 12 Jun'13 - 2 messages
Patrick
you sure about that model number? hyster didn't make an E80V that I'm aware of
got a serial number?
anyhow... if they are designed anything like the Yale electric sit down riders and i suspect they are... the parking brake mechanism is under the floorboard on left hand side, has a cable from the park brake pull handle going down to the park brake mechanism?
If you look on the front side of the park brake mechanism you will see a round **** on it... you can adjust the park brake tighter using that and this will cure your return problem. Yale trucks suffered the same problem when the park brake cables stretched some and they were constantly having to be adjusted to get them to release completely.
IF this is the design this truck has
check it out and see if I'm correct
  • Posted 12 Jun 2013 21:30
  • Modified 12 Jun 2013 21:35 by poster
Forgot to mention, we just pull it up the rest of the way with our foot and it works like normal. This isnt a big problem, just would like to fix it. Thanks again!
  • Posted 12 Jun 2013 05:01
  • By patrick_a
Maxlion FB25EH
Manitou M50-4
