steering locks
Hello everyone. I hope somebody can help me. We bought four of these heli cpd205's. Overall we are happy but one of them serial number 060201d6279. We have an issue with it randomly having the steering get extremely stiff and the speed slowing way down. One minute it works fine then for no reason the steering locks. Has anybody run into thos or have any access to a decent shop manual?
  • Posted 31 May 2014 16:21
  • By shaner
  • joined 1 Mar'11 - 29 messages
  • British Columbia, Canada
Should have 900 psi to orbitrol from hyd manifold
I've seen orbitrol a crap out and pumps as well
  • Posted 23 Jan 2015 12:15
  • By CHEEECH
  • joined 20 Mar'14 - 5 messages
Hi all I have a heli HFB 15 2004..4 wheel zapi
Problem being the truck will get intermittent tight steering
When operating the steering the pump does change note...when the steering goes tight the pump note sounds the same as when under normal load..it's a very simple system but I must admit this problem is giving me a headache..
Is there any pressure points that the pump pressure or orbital can be checked..iv checked king pins and steering ram and links all fine..
Any advice greatly appreciated
  • Posted 13 Dec 2014 05:05
  • By helta
  • joined 13 Dec'14 - 2 messages
  • leicestershire, United Kingdom
Hello send me your e mail. we will try and find some manuals :)
prenticelift at gmail dot com
  • Posted 6 Jun 2014 23:03
  • By Prentice
Hi! Is the steering stiff even if you use sidesift or tilt to the end, and steer at same time. I had once similar issue and the fault was stuck steerin relief valve. Did you mean drivespeed is slowing down at same time? Then it cant be mechanical broplem in hydraulics.
I didnt hear about cpd205? I guess its cpd20 or 25? Is it basic four wheel counterbalance with AC motors and what is the year? I guess you will find zapi manuals on its website. Heli manuals are poor.
  • Posted 6 Jun 2014 05:29
  • By juuso_s
  • joined 6 Jun'14 - 1 message
  • Finland, -
edition #1286 - 18 June 2026
Leading the news in this week’s Forkliftaction News , Hyster launches a new electric counterbalance forklift which it describes as “a high-performance evolution of a proven workhorse”... Continue reading
The charge carried by a bolt of lightning is so intense that it has a temperature of 30,000-degrees C (54,000-degrees F), five times hotter than the surface of the sun which is about 5,500-degrees C (10,000-degrees F).
Steve Strenck Steve Strenck
Director of sales, Gregory Poole Lift Systems
Vice president aftersales Europe, EP Equipment
Chief financial officer, Raymond Storage Concepts
June 23-25, 2026 - Melbourne, Australia
September 15-17, 2026 - SÃO PAULO, Brazil
September 16-17, 2026 - Dallas, United States
