Steer not syncing it won't center
Steering will mot sync up try calibration works for abit then it goes off to right field
  • Posted 24 Nov 2022 02:59
  • By Gusstone
  • joined 17 Apr'20 - 25 messages
knowing combi's , from my past experience it may have a position sensor malfunction? Most of the units i've worked on when the steering has a centering issue it has to do with the sensors not picking up or may be out of adjustment or something to that effect.
But like richard said, you should call combi and don't assume anything.
  • Posted 25 Nov 2022 13:53
Hi Gusstone,
As you are in Canada, can you contact the Combilift US based Technical Team. They are based in Greenboro NC. If you go to www.combilift.com, scroll to the very bottom, you can submit a "Technical Support" request. The form asks for truck SN, contact tel no,etc to help identify the problem and to contact you back. The tech team will then contact you. Here is a direct link here https://warranty.combilift.net/technical-support-form/
Hope this helps,
Richard
  • Posted 24 Nov 2022 03:06
  • By Richard_Irwin
  • joined 20 Feb'20 - 85 messages
  • Monaghan, Ireland
UN Forklift FB25N1QZ1
Taylor TE650S
Bolzoni SpA (Group HQ)
edition #1281 - 14 May 2026
Taylor TE650S
