SPARK GOES AWAY IN # 3 CYLINDER
I HAVE A MITSUBISHI FGC 25K SER:AF82D 00432 THE SPARK GOES AWAY IN # 3 CYLINDER ONLEY WHEN YOU ACCLERAT ALL THE WAYS OUT ,AND BACKFIERS SOME TIME , , (COULD IT BE A BAD CPU)
  • Posted 28 May 2012 11:03
  • By phillboy
  • joined 5 Mar'11 - 7 messages
  • New Jersey, United States
TILT WIILL NOT STAY , KEEP GOING FORWARD WHEN LEVER IS PULL BACK
Hi!
I have a problem with engine Nissan K21072686!It is seems like 2. and 3. piston doesnt work,I replaced control valve, cap an electronic, but again the 2. piston like it doesn't work???!!
If You have manual for this engine, it would be great!Just to see what can be wrong...i was talking with many mechanics , electronics ,but i didn't solved problem!
Best regards!
Dragan
  • Posted 25 Dec 2012 04:24
  • By marija_p
  • joined 27 Nov'10 - 33 messages
  • bosna i hercegovina, Bosnia And Herzegovina
mprolic@hotmail.com
NO , MITSUBISHI 64 ENGINE , ONE COIL , WITH FOUR WIRE PLUG THIS COIL IS USED IN THE CADALAC CARD.
  • Posted 28 May 2012 12:24
  • By phillboy
This have the nissan k21/k25 engine in it with the coil over plugs?
  • Posted 28 May 2012 11:44
  • By kevin_t
