Service manual TCM FB20H4
i need service manual for TCM FB20H4, if anyone have please send it to me. Many Thanks
Mail: longbbs(at)yahoo(dot)com(dot)vn
  • Posted 21 Nov 2014 15:45
  • Modified 24 Nov 2014 16:59 by poster
  • By long_dai
  • joined 3 May'12 - 41 messages
  • 1981, Viet Nam
Does anyone have a sequence of operation list for the drive operation of this unit? My main contactor kicks on and what I believe to be the steer motor is kicking on. The seat switch only shows.7v going to it but I can tell if this traces back to the controller in the dash or not.
The accel pedal gets a 10v feed but when checking resistance, the reading goes from 4.07 to open. Nothing in between.
** I believe my issue is the module in the dash but I need a wiring diagram showing the path of the seat switch feed.
Hopefully y'all can help me out.
I work for an old TCM dealer but we do not have this manual.
  • Posted 29 Jul 2025 08:58
  • By Charles_Kusmier
  • joined 29 Jul'25 - 1 message
Just because its older, don't make it better except for GE.
Checking mail.
Stefano - Italy
  • Posted 9 Dec 2014 05:03
  • By stefano_tcm
  • joined 25 Oct'14 - 110 messages
  • ITALIA, Italy
TCM Forklift spare parts
tcmricambi@gmail.com
hello :) could you please send it for me too?
bschuelle at web dot de
would be ever so grateful.
  • Posted 8 Dec 2014 20:08
  • By blt_s
  • joined 6 May'11 - 35 messages
  • Pest, Hungary
CHECKING MAIL.
PART MANUAL AND WIRING DIAGRAM FB20-25H4
Best Regards
Stefano - ITALY
  • Posted 2 Dec 2014 23:44
  • By stefano_tcm
  • ITALIA, Italy
Thank Stefano!
Can you send for me the electrical-wiring diagram?
  • Posted 2 Dec 2014 18:25
  • By long_dai
  • 1981, Viet Nam
Thank Addy MHE
  • Posted 2 Dec 2014 18:21
  • By long_dai
  • 1981, Viet Nam
Checking mail.
Stefano - ITALY
  • Posted 1 Dec 2014 02:31
  • By stefano_tcm
  • ITALIA, Italy
First confirm that it has control panel on front left side made by Hyundai. Contactor panel is mounted under the foot rest plate. It has Force ventilated drive motor. Drive motor fan is operated by Inverter mounted on Front Right of steering, can be reached by lifting the top plate of front panel.
If yes then check if drive contactors are energising or not, can you hear the contactor sound when you select the drive?
Did you check the small voltage regulator mounted with the main control card, output should be around 13 volts.
Check the accelerator pedal, Setting should be from 0 to 9 volt output.
Confirm above and skype me @ adnan.khalid143
  • Posted 27 Nov 2014 04:05
  • By Addy_MHE
  • joined 9 Jul'13 - 160 messages
  • Sindh, Pakistan
Work Until IDOLS become your RIVALS.
hi Addy MHE
Forklift can't move forward or back
Please help me, how can we do to repair
Thank
  • Posted 26 Nov 2014 16:37
  • By long_dai
  • 1981, Viet Nam
Hi.. i dont have the manual but i worked on these trucks.. if you tell the problem i can guide you.
  • Posted 25 Nov 2014 03:26
  • By Addy_MHE
  • Sindh, Pakistan
please help...
Thank alot!
  • Posted 24 Nov 2014 16:58
  • By long_dai
  • 1981, Viet Nam
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Tusk 350CGH20
Terberg RT223
Yale releases two new products Greenville, NC, United States
