S.A.S light code 54
the S.A.S light is on and the display is reading errr 54 having problems figuring this one out any help would be greatly appreciated
  • Posted 30 Jun 2010 04:16
  • By dusty_j
  • joined 30 Jun'10 - 1 message
  • South Dakota, United States
I am looking for some info on why a Toyota 7FGCSU20 on LPG runs with the air cleaner filter taped off. I was sent to this customer to service this forklift. I removed the air filter and seen that it was completely covered with packing tape. So I thought someone had tried to give the operator a bad time. So I removed the tape and completed the service. Moved the machine a short ways and all was good. A day later the customer was complaining about no power and would die if it had to lift a load. Another Tech went back to the customer and taped the filter up and the customer said the power is good now. This machine has to be getting air from somewhere or is the fuel so backed off that it won't run on full air.
  • Posted 25 Jun 2015 03:53
  • By Gramps21
  • joined 25 Jun'15 - 1 message
  • Wyoming, United States
swing cylinder solenoid, probably broken wires either just above cylinder or right at the coil. cylinder may be missing mounting pin.
  • Posted 30 Jun 2010 11:58
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
The term "Spring", referring to the season, originated in the 14th century as "Springing time", describing how plants "spring" or burst into life after winter. In the 16th century "Springing time" was shortened to just "spring" for the season of new growth.
June 9-11, 2026 - Stuttgart, Germany
