Runs lumpy
Cat GP25, 5AM01193, starts and runs fine when cold, after short time engine starts to miss and then dies. Will start right back up and run for a shorter period then die again, will do this several times with the run time getting shorter each time until it won't start and will sometimes take out ignition module. If you take alternator out of system runs fine and doesn't die, had alternator checked and rebuilt by reputable rebuilder but still same problem, any ideas?
  • Posted 20 Oct 2023 07:23
  • By Elliott_Burdon
  • joined 20 Oct'23 - 2 messages
  • United Kingdom
Elliott Burdon
Thank you for your help ??
  • Posted 22 Oct 2023 19:16
  • By Elliott_Burdon
  • United Kingdom
Elliott Burdon
the only things that could take out an ignition module would be over voltage or a shorted circuit.
make sure that alternator is putting out correctly, generally 13.2 to 14.8v at high governed rpms.
get a good look at the distributor and the wiring, the rubber insulator where the harness comes out of it.
Oh, (just in case) don't use any TVH ignition parts, use OEM please, they work a lot better ;o)
  • Posted 22 Oct 2023 14:56
Hangcha CBD15
China
USD1,600
Terberg YT223
November 3-4 2026 - Houston, United States
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
