removing drive motor
I have a yale model erc070hcn36se085 series D532148 & the electric drive motor caught fire in the brushes area & now does not move, does anyone know what is involved in removing the drive motor
  • Posted 15 Dec 2013 11:26
  • By igloo
  • joined 15 Dec'13 - 2 messages
  • New Jersey, United States
like mrfixit says,
if there is no damage to the armature you can fix the brush housing parts (brushes, springs, bearing) in the frame without pulling the motor.
BUT...
if the armature is scored or damaged from brushes that were worn down too far and caused commutator burning then yes the motor will have to be removed.
You can get the motor out through the bottom with the truck off the floor on wheel block stands and get a jack with a motor cradle attachment and lower it out through the bottom after disconnecting the cables and sensor wires and park brake.
You can also get it out from the topside using a come-a-long and a strap. The manual does recommend getting the truck off the floor to gain easier access to the bottom motor mount bolts.
good luck
  • Posted 21 Jan 2014 21:55
I would start by removing the battery, then you can access the back part of the motor and see what's damaged. You may not need to remove the whole motor, just the back bearing plate with the brushes and brush holder.
  • Posted 15 Dec 2013 23:32
there are a number of people here who do know what is involved, and more than likely, more than a few who have done the job.
There is more than 1 way to 'skin that cat'.
Do you have a more specific question that some of those people could discuss with you, about that job? (more specific than 'do you know how'?)
  • Posted 15 Dec 2013 23:14
Hawker Powersource, Inc.
Hangcha FLDCXT160
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Sue Tomic Sue Tomic
Hangcha FLDCXT160
USD1
Sue Tomic Sue Tomic
