reach/tilt
Reach and tilt wont work when you first power up truck.Then something lets off and all will work.If you get high speed pump on it will work till you shut down or get off pedals.Crown said stuck valve.Replaced the whole block with one from working truck.Calibration was done with both blocks.No change.No codes.And ideals? Thanks
  • Posted 23 Dec 2008 09:31
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Thanks for the info.Truck is still sitting in the shop wainting on me,We must not be that slow.Maybe next week Ill get back to it.
  • Posted 9 Jan 2009 12:28
  • By proshadetree
clean the priority flow valve in the bottom of P1
Does this truck have freezer oil? If so the pump might be worn out.
I have seen bad motor brushes do this as the module cannot sense the load on the pump. Most prolly is the worn out pump not loading the motor...
  • Posted 8 Jan 2009 23:42
  • By marty_b
  • joined 12 Dec'08 - 4 messages
donations required...
On vacation right now but I have the feeling its going to be waiting on me when I return.Thanks I check it out when i get back 36v var pump
  • Posted 29 Dec 2008 03:33
  • By proshadetree
Sorry Proshadetree, I didnt see the header at the top stating RD5000. Same results though.
  • Posted 28 Dec 2008 11:24
  • By roadtek
  • joined 4 Dec'07 - 123 messages
I take it your working on a 5000 series reach. RR5200 maybe?
If so the first thing I would have said would have beed a stuck SVE on the man block, but since you changed the whole block, I might say P-1. I've seen a lot of P-1 failures lately. Symptoms have been no accessory functions unless you turn on P-2 (or on 24 volt systems crank up P-1 speed) & hard steering. If your a Crown tech you know how to see what kind of pump you have ( variable or standard ). I'd put my money there. Feel free to send mod and ser #. How many hours on it?
  • Posted 28 Dec 2008 11:17
  • By roadtek
Aichi SR18A
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
March 25th-26th, 2026 - Ho Chi Minh City, Vietnam
March 31-April 2, 2026 - Paris, France
April 22-23, 2026 - Atlanta, United States
Australia was the first nation to successfully convert its paper-based currency to polymer banknotes, a technology developed in the same country. The first polymer banknote was a commemorative $10 note issued in 1988 to mark the Bicentenary. The first polymer banknotes were also the first to feature a transparent "window" as a security feature.
