Reach fault
Hi there.
Can anybody help with my reach truck problem.
This reach truck works ok except that when I reach in, the reach carraige stops 4" or 100mm from the end of its travel. The only way I can get it to come all the way back is to switch it off and back on then it will come all the way home. Any good ideas of a fix.
Thanks
  • Posted 14 Dec 2012 05:50
  • By kevtwad
  • joined 5 Mar'11 - 76 messages
  • Northumberland, United Kingdom
the most common faults with reach problems in the pantograph is the wire harness getting pinched somewhere or rubbed and the harness shorting or opening up.
I would inspect ALL the wiring in the pantograph and around the manifold valve on the carriage assy. Watch it closely when it all comes together and look for things like this.
The clearances are very tight usually so the chance of this being the problem is very high.
  • Posted 14 Dec 2012 07:32
  • Modified 14 Dec 2012 07:33 by poster
RAEDER-VOGEL
The largest butterfly in the world is the Queen Alexandra's Birdwing (ornithoptera alexandrae), with a wingspan of up to 31cm (just over 12 inches). It is an endangered species only found in Papua New Guinea.
SMV (Konecranes) 4632CC5
UN Forklift FD40T
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
