Raymond 770-DRR32tt Lift with tilt/ss
need help for a Raymond reach truck. All functions work but when we use Tilt, Side Shift or Double deep it start lifting the forks also.
What can be the problem, Schematic or hydraulic service manual will be a great help.
  • Posted 2 Apr 2019 06:00
  • By Addy_MHE
  • joined 9 Jul'13 - 160 messages
  • Sindh, Pakistan
It's definitely your Relief valve.
  • Posted 26 Nov 2024 02:46
  • By D_Lopez
  • joined 25 Apr'22 - 8 messages
DLopez
Did yours keep lifting or did it stop?
I've just run into this same issue, but it only lifts a couple inches when reach/retract/tilt/shift and then works normally. Same or different issue?
  • Posted 5 Dec 2022 07:31
  • By jbierling
  • joined 5 Dec'22 - 1 message
  • Michigan, United States
You are correct.
  • Posted 22 Apr 2019 20:01
  • By stam
Stam, you are very right.
I am not very expert of Hydraulics but spent hours with this valve in last 2 weeks. As per my Learning on this valve; it does not need any electrical connection for Lifting, if there is pressure POD will actuate because of excessive pressure and direct the pressure to Lifting rams. If we remove all coils from the valve it will still be able to lift. It doesn't happen in other machine.
It needs a Pilot pressure from AUX Coils to retain it to the AUX function position. If pilot pressure is there and POD is stuck or not working properly it will keep lifting the Lift rams.
Please correct me if it works differently.
  • Posted 22 Apr 2019 19:03
  • By Addy_MHE
  • Sindh, Pakistan
Work Until IDOLS become your RIVALS.
Nope, pod can do this and does. You'll run across one someday. Typically it's metal caught in the valving on the 7xxx models. Usually the free lift rams shed into the system.
  • Posted 19 Apr 2019 06:38
  • By stam
i don"t think this is a hyd. matter, again, on the other one you were right, but on this i think again it's electrical, could be the buttons on the handle or again the over the mast cable, check continuity on that.
  • Posted 19 Apr 2019 05:29
  • By max_h
  • joined 28 Sep'17 - 13 messages
Hi Max,
Thanks for your input. I services the valve by pulling all valves out and found POD had some resistance. Polished it, bleeded air and it is working fine now.
now other Raymond does the same with Tilt. When you operate Tilt button it starts lifting.
Raymond Hydraulic Valve is not one of the best designed valve which we see in Crown, BT or other leading brands.
  • Posted 17 Apr 2019 18:05
  • By Addy_MHE
  • Sindh, Pakistan
TRY AGAIN ON THE AIR, MEAN IT LIFT ALL THE WAY AND TRY THE FUNCTIONS AND SEE WHAT HAPPENS, IF NOTHING HAPPENS, START LOWERING THE MAST AND EVERY SO AND THEN TRY AGAIN, IF IT HAPPENS, CHANGE THE OVER THE MAST CABLE.
  • Posted 17 Apr 2019 00:25
  • By max_h
  • By max_h
