Ravas-Cascade weighing forks (iFork)
Anyone use this product? Cascade calls it the iFork. Its basically pair of forks with RF load cells and a digital readout. Just wondering on any feedback.
  • Posted 24 Dec 2010 23:51
  • By joe_b
  • joined 24 Oct'06 - 4 messages
RAVAS LLC has now a new generation of iForks - it comes with a Bluetooth output to pair to your iPhone ( Android is also available )
The weight of the goods can be stored in you phone, tare weight and product ID can be added. And at the end of the shift ( or job ) you simply email all data in a batch report (CSV style ) to an inbox for further action
If you use a Zabra terminal on Android... then you can also scan the ID codes
RAVAS Connect Me !
  • Posted 13 Jan 2019 21:04
  • By jacob
  • joined 11 Jun'04 - 11 messages
  • Zaltbommel, Netherlands
weighing without compromise
With iForks you can do even more then just weighing.
Have a look on YouTube key in the search field: ravas mobile weighing db schenker
Here you see how you can also integrate a Volume measurement system plus a handscanner ALL into one WMS of DB Schenker
rgds Jacob Blom
  • Posted 7 Nov 2013 16:04
  • By jacob
The Cascade iForks are quite different than a system which uses a transducer to sense variations in hydraulic pressue in order to calculate weight. (Cascade has that option available as well).
The iForks are a true mobile weighing system with 0.1% accuracy.
The determining factor is what do you or your customer really need from your weighing device? Invest in the solution that solves you material handling needs.
  • Posted 9 Feb 2011 01:38
  • By Kmiller
  • joined 21 Dec'10 - 4 messages
Joe - our parts manager quoted this product once before. Very expensive as compared to other options for forklift scales. We have used a product by AccuLoad a few times. Their price is good and the unit ties into the forklift's hydraulic system.
AccuLoad LTWS-1 Patriot Economy Model Hydraulic Lift Truck Scale
  • Posted 9 Feb 2011 01:21
  • By mark_p
  • joined 10 Sep'10 - 6 messages
http://lifttrucks.ringpower.com
The integrated products have been marketed by MCFA and for a number of years without issues like you describe. This kind of use/abuse is anticipated in the typical environment. Load cell failures have been very minimal and the patented scale design protects against impact loadings. Furthermore the stainless steel hermietically sealed load cells employed are are simple and far less expensive than LCs used in most other products of this nature (as the scale output is digital). The hang on scale is built using similar technologies as the integrated scale and the robustness is comparable.
  • Posted 14 Jan 2011 23:38
  • Modified 20 Jan 2011 23:15 by poster
  • By thomas_r
  • joined 28 May'04 - 8 messages
Years ago I sold one of these and it had strain gauges in it. Like the tech in the weighing bridges for truck stops. Everything great until customer dropped pallet on it and broke it, then mucho warranty finger pointing. Personally I thought that this would happen with most customers at some time.
Anyway maybe the tech is different today
  • Posted 14 Jan 2011 04:17
  • By andrew_j
  • joined 20 Feb'09 - 54 messages
Mettler Toledo, Inc. the largest manufacturer of weighing equipment on earth manufactures and distributes the VFS220-T24 legal for trade hang on scale which operates with a wireless link to a mobile PC in the fork truck cabin. There is approximately 12-15% lost load associated with this device. For certain Mitsubishi and Caterpillar trucks/masts a scale is available that replaces the lift carriage virtually eliminating this hinderance. These scales are legal for trade as well. Information can be found on the Mettler Toledo website.
  • Posted 14 Jan 2011 02:27
  • By thomas_r
Cascade manufactures mobile weighing equipment known as iForks. These are state of the art devices with a very high degree of accuracy. Cascade will be happy to discuss your application or demonstrate a set if you contact your local dealer or Cascade representative.
Best Regards,
D. Keith Miller
Cascade Corporation
  • Posted 13 Jan 2011 23:33
  • By Kmiller
We have two sets at a customer, and they are very satified with them. I havn't had any warranty issues to do either. MEE Milwaukee
  • Posted 7 Jan 2011 07:42
  • By MAK54
  • joined 20 Apr'10 - 14 messages
  • Wisconsin, United States
I did check into for a customer, but felt price was a little high
for a set of forks with RF cells
  • Posted 6 Jan 2011 22:11
  • By Buckeyes1
  • joined 6 Jan'11 - 5 messages
  • Virginia, United States
