R16, 4 intermittent T code
Hi guys, I have a Little linde Electric, sometimes it Works sometime I have 3-4 codes wich is T226, T227, T262 and sometimes T249.
I Found the traction motor fan was burn and Lac fan too, I though IT was over heating but no it still code, câble look fine.
You think the Lac is dead can I Do something to be sûre it is
  • Posted 13 Jul 2021 23:01
  • By Junior40
  • joined 16 Jun'21 - 3 messages
  • Quebec, Canada
I need advice on Code Error T262. how to clear or repair this code. I have checked CAN Hi CAN lo Resistance and voltage.
The codes on the Truck is T226,T227,T262,L226, L227.
any advise Please
  • Posted 9 Oct 2022 23:23
  • By Rhinoforklifts
  • joined 9 Oct'22 - 1 message
  • South Africa
rhinoforklifts@yahoo.com
Hi,
1) T226 =Motor temperature sensor is outside of the normal operating range of -39°C to 214°C
2) T227 = MOS temperature sensor is outside of the normal operating range of -39°C to 214°C
3) T262= CAN signal from LAC are not received
4) T249=Negative different signed ratiometric accelerator (1A4) signals 1 and 2 on Traction/Lift
(< -3[%])
=> First, you must replace the new cooling fan for the traction motor & LAC Power module.
=> Then put the truck back to operation then see if there are any error codes happen anymore?
  • Posted 26 Jul 2021 14:57
  • By Nunanemo
  • joined 24 Mar'19 - 24 messages
  • Viet Nam
Cheers
Nuna - Ho Chi Minh City
Email: dairongservice1973@gmail.com
Website: xenangdairong.com
Linde Material Handling
Hoist Liftruck F180-36BOX-CAR
SMV (Konecranes) 12-1200B
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
