Problem with brakes and forward/reverse
I have a Clark GCX15e forklift that got flooded from two hurricanes. I had so much damage on my home it was four months before I had a chance to look at the forklift because it is at a different location than my house. The brakes were locked up and the pad on one wheel came off with the drum. I changed the oil in the engine and transmission and thought I got all the oil out. No water got into the hydraulics and have no problem with the hydraulics. The forklift will go forward and reverse while it is cold and then will not go either direction and I have no brakes. I bought new brake shoes and seals and just took the two master cylinders behind the steering column apart and cleaned them because there was a 2-4 week delivery and I need my forklift now. I also took the two wheel cylinders and inching valve apart and cleaned them and they all looked good. I would have put a kit in all of them put could not locate them. I cannot bleed the brakes and have no pedal no matter what I do, I have hooked up a vacuum pump to the bleeder valve and at the same time put 18 lbs of pressure on the reservoir cap and that did not help. While I was doing all of that I had someone working the brake pedal. I have finally got fluid on the bleeder on the inch valve but not to wheel cylinder. I have taken all the lines l could get to and blew air through them. I could not get the ones off the valve block on top of transmission and really do not know how to take the whole assembly off and tear it apart and either clean or replace it. I also have 5 gallons of transmission oil and a new filter.
Thanks in advance for any suggestions and help.
  • Posted 27 Nov 2021 01:22
  • By Jim_Flowers
  • joined 27 Nov'21 - 2 messages
  • Louisiana, United States
Jim Flowers
Jim what part of LA are located? We have an older Clark GCX and I'm trying to find a competent service company for maintenance in Kenner or at least near New Orleans. The last co. we utilized did 3 brake jobs in the span of 60 running hours. We use the forklift sporadically so it really doesn't get used very much. I'm hoping you might have a suggestion regarding who we should call.
  • Posted 1 Mar 2023 06:45
  • By kurt_parsons
  • joined 1 Mar'23 - 1 message
I fixed the problem with the forklift not going into forward or reverse after 4 or 5 minutes. The floods ruint my alternator. The forklift ran great and started right up but I had to jump it off each time I used it. Jumping it off but enough charge in the battery long enough to run 4 or 5 minutes and then would not hold the forward/reverse swich and the switch would stay in neutral.
  • Posted 6 Jan 2022 15:04
  • By Jim_Flowers
Still GX10
Still GX10 2000
Poland
EUR950
Mitsubishi FGE35AT
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
