Prime Mover
I am looking for a spec sheet on a Prime Mover OPX30 SN: OPX3033148002
with a 300" Triple and 36 volt system. I would greatly appreciate any help.
  • Posted 1 Feb 2008 09:02
  • By LiftDuck
  • joined 21 Jan'05 - 18 messages
  • Tennessee, United States
The Tiger that does not prowl is a potential
rug!
Thanks....................
  • Posted 16 Feb 2008 03:30
  • By LiftDuck
36 volt unit with fork height under 24"= 6.2 mph empty
36 volt high lift speed=72 fpm empty
high speed lowering = 65 fpm empty
  • Posted 15 Feb 2008 07:25
  • By carl_v
  • joined 12 Oct'07 - 76 messages
I need travel and lift speeds... The units are on skids and I do not want
to assemble and add batteries untill I have to.....
  • Posted 15 Feb 2008 06:03
  • By LiftDuck
What do you need the spec sheet for? All it tells you is everything you have listed above. Maybe an option or two but you should be able to see them on the truck. Example: wire guidance or side gates.
  • Posted 15 Feb 2008 00:48
  • By lifterman
  • joined 5 Feb'08 - 7 messages
  • Iowa, United States
ROYPOW
Briefs United States
ROYPOW
