Password & Fault Code
Good Morning
Can anyone tell us the password to enter the control panel & also the truck is fine but shows a fault code of 676-4 ??
Can anyone shed any light ??
  • Posted 3 Dec 2014 20:16
  • By neil_t
  • joined 9 Jul'13 - 5 messages
  • uk, United Kingdom
these trucks eat batteries and wire harnesses. there are probably multiple codes that are all "OORL". ed is right about access codes, need to contact the dealer. if you enter the wrong code 10 times the machine will shut down permanently and can only be resuscitated by the dealer with a computer.
  • Posted 21 Dec 2014 01:35
  • By versitech
  • joined 16 Dec'14 - 5 messages
  • Washington, United States
Neil, you will need to have the local Hyster dealer to reset and give you the password for this truck, and there are a few levels of passwords. no one else other than Hyster dealers will have the software to be able to access the passwords, and very few people other than Hyster dealers will have the experience to help you with this truck
676-4= Glow Plug Relay Driver Output Out Of Range Low
I take it this is a deisel truck.
  • Posted 3 Dec 2014 22:19
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
