orange blink code on access3 traction controler
Hi, the model of this machine is esr4000 serial 8a102xxx. the dash display is blank, the line contactors do not close, the the blink sequence is 1blink pause 3 blink pause 9 blink pause 4 blink then the sequence repeats.anyone know meaning of this code, also if the dash display is not working will the truck still operate. Thanks.
  • Posted 6 Oct 2024 07:09
  • By stephen_dwyer
  • joined 14 Jun'22 - 12 messages
still learning
Did you recently replace a module? Otherwise listen for the beep from the access1 display when you turn the truck on, if there is no beep then the truck won't operate.
The only time I've seen this is when a new module has been installed but the correct software is not installed. But it definitely sounds like an issue with your access 1 if it is not starting. I'd verify all the wiring and check the can circuit first.
  • Posted 6 Oct 2024 10:24
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 226 messages
  • Wisconsin, United States
Johan Leveque Johan Leveque
Vice-chair, ALICE - (Alliance for Logistics Innovation through Collaboration in Europe)
Co-CEO, LIS Logistische Informationssysteme (LIS)
Regional sales manager, Battery Builders
SVP business solutions for the Americas, Dematic
edition #1268 - 12 February 2026
In this week’s Forkliftaction News we look at the life and legacy of Manitou Group’s Marcel Braud, who has passed away aged 93... Continue reading
The term "Spring", referring to the season, originated in the 14th century as "Springing time", describing how plants "spring" or burst into life after winter. In the 16th century "Springing time" was shortened to just "spring" for the season of new growth.
Taylor TX330S
USD159,500
JLG G12-55A
