Ongoing steer control issue
First let me say thanks for all the info I have found here already.
Our "service tech" was positive that we needed a new steer control board at a cost of $2100.00. The tech replaced the steer position encoder as he thought that was the problem. I instead sent ours off and had it serviced for $400.00. I installed the controller and went through the calibration. All seemed fine for a few hours then code C3 again. I then went back through calibration and same thing 3 hours later. Doesn't feel like excessive play in pivot bearing while jacked up. So I guess I'm down to either steer encoder or home proximity sensor.
Any thoughts on what I may be missing or overlooking?
Tom
  • Posted 16 Feb 2011 11:40
  • By Steel
  • joined 16 Feb'11 - 2 messages
Hello, What ended up being the issue on this? Where are you located in SC? Just wondering.
  • Posted 6 May 2015 08:36
  • By Hero5
  • joined 17 May'14 - 56 messages
It appears that the master for the deadman switch is bad. Will know for sure Monday morning.
  • Posted 19 Feb 2011 23:15
  • By Steel
Terberg RT223
Ncn 110TH
Ncn 110TH 2015
Philadephia, PA, United States
Chandler, United States
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Terberg RT223
Ncn 110TH
Ncn 110TH 2015
