older yale clamp truck error
My company has an older yale clamp truck that won't move it is a model# ERC050ZFN36SE084 I can't find any information about this model and it won't move and is giving an error code 42.
  • Posted 23 Jan 2019 22:56
  • By printer
  • joined 23 Jan'19 - 6 messages
-93 is a steer motor brush wear fault. -142 is open shunt sensor on the pump controller. This is the same fault you had on the traction controller.
  • Posted 25 Jan 2019 00:36
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
ok now it moves but the hydraulics don't work and while moving it has an error code -93 and when you try to use the hydraulics it gives a code of -142
  • Posted 24 Jan 2019 22:53
  • By printer
it has an ev-100 control but the error is exactly -42 so I will have to find an electrical diagram the last technician to come out took all the books with him.
  • Posted 24 Jan 2019 22:23
  • By printer
Check the green wire that connects to PZ4 plug from the SCR1 current sensor. -42 fault is open sensor.
  • Posted 24 Jan 2019 09:21
  • By BREWSKI
Hello.
That is a electric forklift correct?
Look at the control model that probably is a ZAPI model and make a search in the web for that ZAPI model.
You can also send me a picture of the model and i try to see something.
  • Posted 24 Jan 2019 08:24
  • By BrunoBatista
  • joined 25 Apr'18 - 12 messages
  • Setubal, Portugal
Terberg RT223
UN Forklift FD25T-C2JM1
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
