no forward or reverse
changed safty relay under control panel, machine was doing work at the time then stopped going for and rev hydrolics still work up and down, tilt and side shift any suggestions thanks
  • Posted 21 May 2013 02:44
  • By redmike
  • joined 21 May'13 - 1 message
  • Iowa, United States
Check the parking brake switch.
  • Posted 21 May 2013 23:45
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
First thing I would check is for a blown fuse for the FWD/Rev Switch's and solenoids...then check the inching pedal/cable and spool to make sure it isn't hung up and keeps the truck stuck in neutral.....what is this safety relay that you are talking about?? Have a Full Model AND serial number of the truck??
  • Posted 21 May 2013 08:55
  • By kevin_t
