No Accelerator Stumped
sn A2h503400 dual fuel, no accelerator in either mode. Continuity wire check from terminal to terminal on 6 wire APP & 6 wires on TPS to ECU. Check for all recommended voltages at all specific terminal-ok. Replaced APP pot, ETC unit and ECU. Check ETC relay-ok suppling 12 volts to ECU. No codes-run scan with Hitachi hand set. APP shows to be working, 0.95v @ Idle, @ WOT 3.75v on both 1 & 2 Sensors. TPS 1&2 sensors shows 0.97v @ idle, 1.25v @ WOT (which on a working truck I've seen these voltages higher-which I believe is why I am not getting acceleration) I am not sure what else to check for, no acceleration, no codes, starts & runs relatively easy. Any help would be appreciated.
  • Posted 15 Jul 2021 02:13
  • Modified 15 Jul 2021 02:15 by poster
  • By BATT
  • joined 25 Apr'17 - 16 messages
  • Michigan, United States
Yes, that is were I am getting the specifications from. According to the manual on terminal 50 (TPS1) of ECU it should have 0.6 volts, terminal 69 (TPS 2) should have 4.5 volts. However I have been told by more than one that those parameters are misprinted (swapped around) in the TCM and Nissan manual.
I am getting 4.5v on term 50 (TPS1) and 0.6v on 69 (TPS2)
  • Posted 16 Jul 2021 21:24
  • By BATT
Hello,
Have you Service Manual ??
Regards
Stefano
  • Posted 16 Jul 2021 18:40
  • By stefano_tcm
  • joined 25 Oct'14 - 110 messages
  • ITALIA, Italy
TCM Forklift spare parts
tcmricambi@gmail.com
Chandler, United States
Philadephia, PA, United States
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
Still GX10
Still GX10 2000
Poland
EUR950
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
