nissan platinum error codes.
Have a CUGL02 nissan. fault has been repaired. Any ideas on clearing code off dash by using "throttle pedal mode". local dealer reluctant to help without sending out their own tech at a cost.
  • Posted 21 Jan 2007 10:42
  • Modified 21 Jan 2007 18:24 by poster
  • By dave_b
  • joined 21 Jan'07 - 7 messages
  • South Australia, Australia
My company ended up using an independant tech with the nissan program to clear it. but the same driver ended up overheating another one which brought the code up. So ill find out today when radiator goes back in. Someone has also suggested using the mitsubishi program which should basically be the same as they're pretty much the same unit.
Ill let you know the result.
  • Posted 31 Jan 2007 06:21
  • By dave_b
Did this work for you?
  • Posted 28 Jan 2007 11:44
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Thanks, i'll give it a go.
  • Posted 22 Jan 2007 06:58
  • By dave_b
Might unhook batery for overnight.Had sevral ppl say it worked for them.
  • Posted 22 Jan 2007 05:14
  • By proshadetree
Briefs United States
