nissan N1
I have a electric AC nissan, and this one have a 2 days new 36v battery with complete charge and change the maine power fuse, my trouble is in the display shown "recharge battery".
and in the confuguration software of the forklift, want to change from 48 to 36 v, and I cant, the software change the parameter but not record, all parameters saved it, except the battery volts.
any one knows about this forklift???
  • Posted 25 Nov 2013 05:07
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
I very appreciate your comment, i find the trouble with the change of the parameter,
was a broken wire, change it and, i could change from 48 to 36v.
now, in this one (forklift), i find another trouble, the stop switch wires burn it, and a lot of work to do.
  • Posted 1 Dec 2013 07:08
  • By raul_s
I wished i could help you but as it is copyrighted material and i live in the USA, i cannot share this info. The lights are pretty straight foward. You will have to change from 48v to 36 volt if using 36 volt battery.
  • Posted 30 Nov 2013 12:36
  • By RCAV8TOR
  • Alabama, United States
Thanks for your info.
Now I try to fix the combination lights, but I have not the diagram for this, any one can help me and share the wiring diagram and schematics for the entire electrical system or at lease the lights front and rear please!!!
Nissan model G1N1L20V CHASSIS # G1N1-720489
  • Posted 27 Nov 2013 05:57
  • By raul_s
Once you select 36v are you entering it or selectingit with #5 key? If you cannot change any of the parameters then you have a dash lock combination you will have to enter to change parameters. Once parameters are changed, you can relock the dash.
  • Posted 26 Nov 2013 08:16
  • By RCAV8TOR
hi raul the forklift that you have has never been 36v unit it is only 48v I take it that it is a 1N1 unit ?? you cannot change it to 36v
  • Posted 25 Nov 2013 18:18
  • By electrotech
  • joined 15 Apr'13 - 65 messages
  • Victoria, Australia
Reach for the sky
Toyota launches three new stackers Columbus, IN, United States
GemOne
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Board member, UKMHA
