Nissan K25 Dual fuel propane bypassing to carb
There is a small port in the carb that leaks propane as soon as the key is turned on. I'm thinking it must be a bad "fuel injector sensor". Removed sensor to see if there was any obvious damage but nothing obvious. Truck runs good on gas and will start on LP and accelerate ok but won't idle due to too much propane. Anyone else seen this issue?
  • Posted 27 Apr 2024 02:03
  • By Rob_B
  • joined 27 Apr'24 - 2 messages
Thanks Scott,
That was the problem. Appreciate the help!
Rob
  • Posted 8 May 2024 00:51
  • By Rob_B
Look at the nikki lpg converter possible truck is getting to much gas pressure on the top f the converter there is a nut with a Phillip's screw drive slot take the nut out and install a gauge turn key on you should see about 5psi. Drain tank down before removing nut also there is a oring dont loose it or it will leak when you put it back.
  • Posted 29 Apr 2024 22:57
  • By Scott_
  • joined 16 May'21 - 342 messages
Scott
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
UN Forklift FBRP15NQZ2
Taylor T650L
Taylor T650L
