Need new engine
Need new engine for S120XLS SN: DOO4V07733R
What's the part number?
are all the gm4.3 engines the same?
looking for new long block ready to install
Thanks
  • Posted 5 Jan 2014 08:34
  • By Parkway
  • joined 21 Jan'10 - 83 messages
pkwyls AT verizon DOT net
Showing items 1 - 19 of 19 results.
sure the bare block would fit in most machines that house a Vortec V6 block, it's the options and accessories that make the difference.
  • Posted 28 Jan 2014 21:28
  • Modified 28 Jan 2014 21:29 by poster
Update. The engine was not the right one. for this truck. needs HY3124588 is reman & new is HY383134
Power Solutions International. was a big help helping ID motor
  • Posted 28 Jan 2014 02:51
  • Modified 28 Jan 2014 02:52 by poster
  • By Parkway
It does fit other machines they have. a lot of things people do don't make sense!
  • Posted 9 Jan 2014 13:48
  • By Parkway
it fits what it came out of ;o)
  • Posted 9 Jan 2014 10:30
No disrespect- just doesn't seem to make sense to rebuild an engine to keep in stock for equipment it might not fit.
  • Posted 9 Jan 2014 09:35
  • By bbforks
of course!!
  • Posted 9 Jan 2014 02:41
  • By Parkway
Did you make the customer aware that the rebuilt engine may not fit other equipment?
  • Posted 9 Jan 2014 02:25
  • By bbforks
quoted customer both ways. I did find some numbers on block 10224534 indicates 93/1994 bought the 4.3LLT The customer wants new and have old one rebuilt for stock for other machines.
thanks for all replys
  • Posted 9 Jan 2014 02:17
  • Modified 9 Jan 2014 02:18 by poster
  • By Parkway
I always give a choice when pricing an engine- rebuilding theirs & an exhange unit. I advise them of the pros/cons of each choice & let them tell me which way to go.
I do prefer rebuilding theirs when possible. I know who's rebuilding it & there will be no installations issues.
  • Posted 9 Jan 2014 02:00
  • By bbforks
oversize piston make the cilinders too close to each other for this typ of engine ! for warranty and prise it is better by new the difference is not large enough
  • Posted 8 Jan 2014 19:43
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
yep i'm sure a rebuild of THAT motor would be cheaper than 118k by a longshot ;o)
  • Posted 8 Jan 2014 10:45
Looking that up on TVH X-part and it shows a part # 1369493 for a 1994 model which crosses to that LLT motor you mentioned. The 1995 motor (1377796) also crosses to the LLT but the 1993 does not. What's wrong with fixing the motor that's in it?
  • Posted 8 Jan 2014 07:14
the engine is rather old, there may be a chance the id tag is still on the block. If not then there should be some numbers stamped in it somewhere. IF there is a tag though it should have the year of mfg on it.
$118,594?
whoa!
did you tell the guy you just wanted a motor and not a whole lift? ;o)
sheesh thats high for a motor
  • Posted 8 Jan 2014 05:36
talked with parts guy at hyster "S$S" he gave me part # 3182721R
I ran that thru TVH cost was $118,594.14 shows it to be R&R engine and no cross-reference to other numbers. R stands for year of manufacture does that mean it has a 1994 engine thats million dollar question
  • Posted 8 Jan 2014 03:05
  • By Parkway
i'm sure because of the age of this truck hyster will have to be contacted directly to get the right information to get you the correct motor. The online database does not cover trucks this old via serial number entry.
I wouldn't trust TVH on this one either.
go direct to the source for your best results.
  • Posted 7 Jan 2014 21:31
  • Modified 7 Jan 2014 21:33 by poster
FYI A serial # ending in "R" is 1994
  • Posted 7 Jan 2014 06:54
If you have to have brand new GM engine get a hold of the guys at Power Solutions International. They are very knowledgeable when it comes to the GM engines. Their website is wwwdotpsienginesdotcom replace the dot in the web address with a actual period.
  • Posted 7 Jan 2014 02:52
  • By Partsguy5
Was going to order the GM4.3LLT from TVH, I have sent in a few requests asking if this is right motor and have not gotten reply back.
It says will fit 1997-2004 & 2008+
I have no idea what year this lift is by the sn; #
  • Posted 7 Jan 2014 02:29
  • By Parkway
No, there are at least 5 different and not interchangeable 4.3 GM motors. you will most likely need the same -year- and an industrial or marine engine, make sure you save the crank case pan from the old motor.
  • Posted 5 Jan 2014 09:05
  • Modified 5 Jan 2014 11:11 by poster
Tusk 500PGH16
Taylor TE650S
