moving problems
Hi! I had a problem with this one. When i press throttle, there is a little pause then a sudden start of moving. when i remove foot from throttle, he breaks instantly. the foot break is o.k. transmition type is hydrostatic and brake too. Is this normal? Moving pallets in this condition is very hard. Anyone knows what to do ? Thanx in advance
  • Posted 27 Jun 2010 20:27
  • By goran_j
  • joined 26 Jun'10 - 7 messages
  • Belgrade, Serbia
There is one microswitch bellow pedal for forward and one bellow pedal for reverse. And there is a rotary position sensor 0-5 V linked with levers for throttle, who drives one step motor which fisicaly move lever and control how much rpm's will engine deliver. I replaced brushes on step motor and he works fine now. The only way to adjust idle is to adjust lever lenght and increase it a bit. Everything else goes from one control box located below fuel tank. Tommorow i try to adjust idle and see if this can eliminate that suddent start. If anything else you want to add please do. So far you helped me a lot. Thank you very much.
  • Posted 28 Jun 2010 01:14
  • By goran_j
  • Belgrade, Serbia
You may have a bit of miss adjustment between the throttle and transmission pump levers/linkage. The engine should slightly increase RPM (from about 650/700 rpm to about 850 rpm) before the transmission tries to move, and then they should be working pretty much together. I am not speaking about this particular model and serial number, (so the factory specs for RPM may be higher or just different) but for hydrostatic transmission powered equipment in general.
I don't think I can recall how Clark put the linkage together for a Hydrostatic.
  • Posted 28 Jun 2010 00:41
  • Modified 28 Jun 2010 02:04 by poster
O.k. Thanx 4 that, 'cause this Clark is first one 4 me to deal with. Usualy i work on TCM. Main problem was that i repaired engine malfunction(full throttle on start-up, caused by jammed fuel pump). And now customer says that this kind of movement is not normal. I tried to drive it and in whole range of throttle he goes fine. Sometimes there's a little pause to throttle response, usualy on small pressure on throttle pedal.
  • Posted 28 Jun 2010 00:19
  • Modified 28 Jun 2010 00:35 by poster
  • By goran_j
  • Belgrade, Serbia
this is normal for any hydrostatic transmission. you will have to get used to the motion changes, and soon you will find that it is even easier to accurately, quickly and safely move pallets.
It is different, but there is considerable reason to believe it is better, once you are used to the difference.
  • Posted 27 Jun 2010 22:37
SMV (Konecranes) 4632CC5
Unicarriers FHGE35T5S
Stu Jacover Stu Jacover
Chief executive officer, TVH
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
