mini levers
I have a code showing the resistance is out of spec on the lift lever on start up. Is there a method to match the resistance to the controller so it will see this as the starting resistance? One I pull the lever back a fraction of an inch, the hydraulics work fine.
  • Posted 2 Mar 2016 02:48
  • By ramon_m
  • joined 30 May'14 - 42 messages
Thanks Brewski
  • Posted 3 Mar 2016 00:57
  • By ramon_m
If the lever is not centering there is no way to calibrate that. The lever must be replaced.
  • Posted 3 Mar 2016 00:56
  • By BREWSKI
