Mast raises when turning
We have a lift that the mast raises when any axillary function is requested and the handle is slightly depressed. We found a faulty svby valve and replaced it but it did not fix the problem. Any help is greatly appreciated!
  • Posted 1 Apr 2021 01:18
  • By NoOne
  • joined 1 Apr'21 - 1 message
  • Utah, United States
Whenever this happens you need to make sure the multitask handle base is not worn out before replacing your lift/lower pot, the detent worns out causing the issue. Generally I replace the base and the pot since I'm already in it.
Ps: excessive play on multitask handle is an indicator of a worn out base.
  • Posted 3 Apr 2021 03:57
  • Modified 3 Apr 2021 04:09 by poster
  • By cubapnea
  • joined 3 Apr'13 - 24 messages
If it ain't broken...you know...
Sounds like the lift pot needs to be calibrated. you can also check the phillips screws on the inside of the yellow half-sphere shaped cover. they come loose and cause unwanted play in the handle that effects neutral position for lift and travel
  • Posted 3 Apr 2021 02:03
  • By Triggs
