main lift continues to climb on own
Replaced pot according to srvice manual learn cntrol and the lift will continue to climb for a second then abruptly stop no fault codes
  • Posted 7 Nov 2013 07:34
  • By liftv5
  • joined 5 Oct'13 - 33 messages
Adjusting the proportional valve seemed to correct the issue thanks
  • Posted 9 Nov 2013 03:35
  • By liftv5
sounds like a valve issue. have you done a weight learn? there is a procedure to adjust the proportional lift/lower valve. if you center the adjustment screw it is usually close enough to work ok. one other thing check the configuration and ensure the dump valve is turned on if you have it.
  • Posted 7 Nov 2013 10:48
  • By stam
TCM FD80Z7
TCM FD80Z7 1990
Big Joe PDR30-154
USD7,500
