Machine can't Start
We fitted a new high Pressure pump (VW03L130755A) on an H50D forklift serial No.:H2X394D50367 and it worked. The next day, it couldn't start. We observed that the fuel level was below minimum as so we topped it up and it worked for about 30 mins after washing the engine it went off again. The next day it started and worked for only about 10 minutes and then stopped again. We have since not been able to start it. No static fault codes appear. Only sporadic fault code P0090 and P0087 appear and has since been cleared. All fuel lines were bled and no leakages were observed after checking.
Can anyone help me out on this?
  • Posted 28 Apr 2016 02:50
  • Modified 28 Apr 2016 02:50 by poster
  • By emmanuel_a
  • joined 28 Apr'16 - 1 message
  • Ghana, Ghana
Check all the plastic tee pieces on the cambelt side of the engine.
Suspect you have a piece of swarf fromt he tank or tee pieces when they were made.
  • Posted 3 Jun 2016 12:05
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
