LRG 425 engine with efi
Hi all!
I have a big problem with a Ford LRG 425 efi in a Genie S45 serie6077.
The engine turn very well on Lpg but on gaz it turn like 3 cylinder and ossillate.
At low idle it start bad but stabilise much after a time.. on high idle it run like 3cylinder on 4 and hesitate
I tried a lots of things to correct that with out succes! but when I disconnect the 2nd engine coolant sensor the efi sistem work well! I tried 2 new sensor and it change nothing, i think the efi engine go in loop mode when I disconnect it but I dont understant what is the problem when its connected. All other sensor seem to be ok.... :/
Tried: Brand new map, Fuel rail rail assy with 4 injector from other 425, throtle body with intake and ait, temps sensor #1(choke switch) and 2nd sensor, ecm, cam sensor(change nothing pluged or not..???), crank sensor seem to be ok because engine dont start if wire short.
Spark plug brand new, gapped...compression 180-185psi on 4 cylinder, no coolant leak(stay at 20Psi on test),I'm about to verify the wiring harness monday but why can cause thats only runing well with a ECS engine coolant sensor disconect??? I have the model with ford Service adaptor who take 2 ecm connector to 2 other with cam sensor, somebody know that?????
No error code except if I disconnect something!
Some other ideas on my problem please????
Tried brand new gaz too!
  • Posted 23 Feb 2019 15:13
  • Modified 23 Feb 2019 15:32 by poster
  • By Mike2000
  • joined 26 Oct'18 - 14 messages
  • Quebec, Canada
i did figure it out , you can call me 845 626 3412 ask for tonyk
  • Posted 24 Mar 2020 05:01
  • By warden
  • joined 19 Mar'20 - 3 messages
was your timing belt changed near the time this began ? thanks tony 845 901 1820
  • Posted 20 Mar 2020 05:30
  • By warden
Hi have the exact same issue with 1999 45/25J ford LRG-425 anyone get a handle on this ? its driving us nutz thanks tonyk 845 901 1820
  • Posted 19 Mar 2020 08:33
  • By warden
Mike,
Did you ever figure out the issue with your machine? I am having the same problem with my Genie Z45/22. I would appreciate you sharing what you discovered.
Thanks
  • Posted 17 Jan 2020 14:09
  • By Steve_Burleson
  • joined 17 Jan'20 - 1 message
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Hawker Powersource, Inc.
Terberg RT403
SMV (Konecranes) 33-1200C
Philadephia, PA, United States
Chandler, United States
