LPG Vaporizer
What is the use of an LPG Vaporizer?
  • Posted 28 Sep 2022 00:54
  • By Iqra_Bashir
  • joined 28 Sep'22 - 1 message
  • United Arab Emirates
An LPG vaporizer is a device used to convert liquid propane or LPG (liquefied petroleum gas) into a gas form, allowing for easier distribution and use in various applications like heating, cooking, and energy production. For a great range of LPG vaporizers https://i-maximum.com/products/lpg-vaporizers, I recommend checking out I-Maximum's site. They offer reliable and efficient models like the KBV and KEV series, designed to suit different capacities and needs. You'll find quality options to meet your specific vaporization requirements there!
  • Posted 20 Dec 2024 02:35
  • Modified 23 Dec 2024 19:31 by poster
  • By milana_miss
  • joined 14 Dec'24 - 1 message
  • Illinois, United States
One thing with LPG trucks is the anti-freeze. If the coolant system is low on anti-freeze and mainly water it may freeze up in the vaporizer.
This cuts down the flow of water through the vaporizer.
I've had this happen loads of times over the years.
  • Posted 22 Feb 2024 22:49
  • By deepdiver
  • joined 5 May'12 - 6 messages
  • Suffolk, United Kingdom
gray haired old git
Hello. Did you manage to find a better gas supplier?
  • Posted 8 Feb 2024 04:46
  • By Mikiki
  • joined 8 Feb'24 - 1 message
  • United Kingdom
UK, has anyone heard of any action taken against the major LPG suppliers. We have 3 machines breaking down monthly at £300-£400 each per time.
Going to experiment with using an alternative supply on one machine to see if it makes any difference.
  • Posted 21 Jun 2023 18:02
  • By LPGSufferer
  • joined 21 Jun'23 - 1 message
  • United Kingdom
HD-5 LP is what the book calls for. Does anybody have experance with HD-10?
  • Posted 27 Feb 2023 21:24
  • By Dexter1212
  • joined 30 Nov'21 - 65 messages
We're are having massive issues with lpg quality and have issued several safety alerts over this issue
  • Posted 24 Feb 2023 10:29
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Thanks swoop223. In both instances the customers were using a bulk gas supply for their respective sites from 2 of the UK's leading suppliers. One was using Calor Gas & the other Flogas. Thanks for your insight.
  • Posted 24 Feb 2023 01:58
  • Modified 24 Feb 2023 01:58 by poster
  • By Supertony66
  • joined 21 Mar'19 - 4 messages
  • Milton Keynes, United Kingdom
hi supertony,
yes we have that issue over here in the states too.
the problem is oil in the gas that gets inside the vaporizer and clogs it up. Yes all LPG has a certain amount of oil mixed with it to supply lubrication and odor to the gas.
in our factory training one of the steps in a maintenance operation is to remove the plug out of the bottom of the vaporizer and let the oil drain out of it.
it seems the reason the oil is getting into the tanks is the LP supplier is not draining their own supply tanks or not filtering it like they should so when they fill the small tanks they get a lot more excess oil in them. This is contaminating the forklift system more than usual causing the starting/running issues.
And yes, most of the time they will deny this, once in a blue moon you might find a distributor that admits to it and tries to keep that from happening.
HD5 is the recommended grade of LPG for most machines so that might be something to consider asking the supplier about. (this is usually the customer's responsibility but you should make sure they know it, customers will try to buy the cheapest they can find but i've found quite a bit that the cheap gas is not HD5 even thought the supplier claims it is).
  • Posted 24 Feb 2023 01:44
  • Modified 24 Feb 2023 01:45 by poster
Here in the UK we are having issues with Gas Vaporizers from a "cold start" point. We believe that this is due to LPG quality issues but the LPG suppliers are denying this. Anyone else experiencing this problem?
  • Posted 23 Feb 2023 18:57
  • By Supertony66
wow thanks for the lesson this is cool
  • Posted 30 Sep 2022 00:12
  • By Manuel_Matic
  • joined 15 Sep'22 - 8 messages
it is a liquid propane gas converter
liquid propane enters, is heated by the coolant flowing through the outside chambers and causes the liquid to evaporate into a gas/vapor which is then distributed to the mixer on the engine which regulates the fuel flow allowing the engine to run in a controlled manner.
ie: it turns liquid into a gas/vapor
  • Posted 29 Sep 2022 22:04
Maxlion FDR50
Taylor TXB180S
Maxlion FDR50
Taylor TXB180S
