linde h80 traction problem
hello, we have a linde h80t-03 from 2007, 353 series, and if i push the pedal for reverse travel gently it go back if push a little bit more truck suden stops with a strange noise it wont go back, but if i push the reverse travel to maximum it goes back normal but at full speed, the forward travel is working perfectly.
any idea what to check?
  • Posted 8 Mar 2017 06:49
  • Modified 8 Mar 2017 06:49 by poster
  • By daniel_a
  • joined 14 Mar'13 - 121 messages
  • ARGES, Romania
do you have fault code in the display after stopping?let me know
  • Posted 12 Apr 2017 21:58
  • By wilson_b
  • joined 19 Oct'15 - 18 messages
  • RIYADH, Saudi Arabia
Yes there is a port
Just trying to remember where it is
One for Fwd and one for Rev
They should be next to the high pressure relief valves.
Also you try swapping the high pressure relief valves around. Fwd to Rev and Rev to Fwd.
Could be as simple as your Rev relief valve could be faulty.
  • Posted 22 Mar 2017 21:18
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
no i did not check the high presure, there is a port where i can check the high presure?
  • Posted 22 Mar 2017 18:19
  • By daniel_a
  • ARGES, Romania
Hi
Have you checked the high pressure of forward and reverse?
Are you sure your not loosing high pressure in reverse?
  • Posted 22 Mar 2017 17:33
  • By Lindetech
hello
today on Sunday we bring another linde h80 which is same model and year, an swap from the 2 machines, the travel control unit, the power limiter and the servo block and make no difference is still stoping in reverse at half pedal. and it makes a strange noise when stops. and the other forklift goes very well with the parts of the bad one.
then we switch the hoses E and F from the wheels motors and the truck behave a little bit better, theat means as only stop in revers when it has a heavy load and steer at maximum, but is limited in speed the engine revs at the top but is getting less speed, but this is no problem.
but i am afraid this is temporary because i think soon will wear and will do the same.
do you have any idea what will be the cause of this malfunction after we change the parts we mentioned above?
  • Posted 20 Mar 2017 08:14
  • Modified 20 Mar 2017 08:15 by poster
  • By daniel_a
  • ARGES, Romania
Engine rpm is also controlled by the travel control unit port v. That supplies the little cylinders for engine rpm.
If you are not achieving rpm in reverse I would still be looking at the travel control unit.
Not unless you are loosing pressure in the power limiter (block on side of the pump)
  • Posted 12 Mar 2017 06:23
  • By Lindetech
First time i was thinking it îs the travel control, but when i switch the hose for y to z to switch direction, If it was the travel control it should drop the presure when is going forword but not îs still droping presure only on îs reversing, this îs 2 pedals Machines.
Could be the servo the piston for backword lousing presure and the travel control does not have enough presure for brakes and also for the engine speed. I also notice that the engine does not revs în revers like it revs în forword.
  • Posted 11 Mar 2017 19:56
  • Modified 11 Mar 2017 19:57 by poster
  • By daniel_a
  • ARGES, Romania
The travel control unit also has a 13 bar valve in
If the pressure drops below 13 bar the brakes will be applied. Sounds like this is happening on your machine
  • Posted 11 Mar 2017 19:38
  • By Lindetech
I would suggest that there could be a problem with your travel control unit then. As br line does not go to the servo unit. Can you block the br port on the travel control unit and see if the pressure is still dropping off when you release the hand brake and try driving.
  • Posted 11 Mar 2017 19:36
  • By Lindetech
I switched the hoses from y to z and know when i push the pedal forword it go backword, and the truck is still stoping
In reverse, no change.
  • Posted 11 Mar 2017 18:12
  • By daniel_a
  • ARGES, Romania
Hello and thank you for the suport
I do not have 2 presure watchs to see the diference between y and z, will buy another one and y will check it on monday, but i check the port BR of the travel unit which goes to the brakes, and i have 17 bar with Engine at idle and brakes release when i push to go forword the presure slightly increase do 20bars, but when i push to go to reverse the presure drops to 10 bars and the motor goes jerky i push more the presure drops to 0 and truck stops with a strânge noise.
How do i check the servo unit?
  • Posted 11 Mar 2017 16:53
  • By daniel_a
  • ARGES, Romania
Firstly check you travel control unit which the pedals attach too.
Secondly I would be checking the servo unit on top of the pump. Also check the pressures on the y and z hoses on the pedal assembly. When you start the machine both pressuresides should come up together. When you slowly press a direction pedal , one will increase.at a difference of 4 bar the wheels should start to rotate.
  • Posted 9 Mar 2017 22:51
  • By Lindetech
Terberg RT223
Aichi RX07B
Powerfleet
AI-enabled safety and compliance solutions for material handling operations.
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
