LINDE 386 - Error L306_L272, L299
Hello everyone.
I have a problem with LINDE E16P-02, H2X386F..., 2015
The operator incorrectly connected the battery plug when replacing the battery (it was broken without a pin).
After correct connection - no reaction.
Replacing the fuse F2 (Fuse before emergency off switch 15 A) started the truck.
Only a twist works. The trolley does not move, it seems to be held by a brake, because you feel that it wants to go. The hydraulics don't work, you hear the pump running. Lighting and heating do not work.
After starting, the errors are shown on the display immediately.
I quickly determined that 2 48V / 12.5V 150W transformers are damaged.
Can damage to these transformers cause hydraulic errors?
Communication with all drivers is via canbox. Only the hydraulics report errors.
  • Posted 20 Nov 2021 09:39
  • Modified 20 Nov 2021 09:39 by poster
  • By tomason2
  • joined 5 Apr'15 - 53 messages
  • Poland
serwiswojnarowski@gmail.com
Hey, I seen you fixed your issue, I am having a similar issue with just codes 306&299. Is it possible to clear the codes or is it a dealer thing? I have also swapped my 15a fuse.
Which transformers had damage?
  • Posted 28 Nov 2024 08:16
  • By dylan_melanson
  • joined 28 Nov'24 - 1 message
  • Nova Scotia, Canada
Dylan
272 PWM signal not correct: Accumulator charging valve
299 Measured current on accumulator charging valve high \
306 Measured current on accumulator charging valve too high
  • Posted 27 Dec 2021 11:39
  • By michel_v
  • noord holland, Netherlands
After installing new transformers, the lighting came back, but still errors on the display. It turned out that the LDC was damaged.
  • Posted 26 Dec 2021 10:47
  • By tomason2
  • Poland
Hello , possible the hydraulic control damage also.
  • Posted 25 Nov 2021 20:47
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Yale Lift Truck Technologies
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Toyota 02-8FD30
