Lifting Slow too soon
When raising carriage the lift is starting to raise slow too soon. How do you change the setting to get the mast to raise slow within the foot from top?
  • Posted 22 Apr 2017 00:41
  • By Chip
  • joined 25 Feb'16 - 13 messages
  • Wyoming, United States
Apparently the "Features" setting was at Zero and one of our guys reset the settings along with others. Thanks for the help
  • Posted 4 May 2017 10:58
  • By Chip
Make sure the height is programmed in the features is correct to the data plate first. Then check the adjustment on the mast chains and calibrate the height encoder. Encoder is calibrated by calibrating the lowering valve just make sure you raise to full height of mast and not to just up to whatever so you will have to be careful of overhead obstructions
  • Posted 23 Apr 2017 23:07
  • Modified 23 Apr 2017 23:10 by poster
  • By popeye
Height encoder
  • Posted 23 Apr 2017 13:13
  • By Chip
It depends if it has a height encoder or if it has a 12 inch switch
  • Posted 23 Apr 2017 09:10
  • By popeye
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
